GB venting???
Dave_22
Member Posts: 232
Anyone???
I am about to install my first GB-142/24
My question is the install manual doesn't specify the minimum distance between the inlet and exhaust on a sidewall vent installation. What is the concensus on this??? Thanks.0 -
10\" apart
We keep ours 10" apart and have never had a problem.
Hope this helps.
Mark H
How about making it easy?
Use the approved concentric vent kit, and only make 1 building penetration 4". Chris0 -
I was going too, but I have to angle the exhaust away from where it exits the house to keep 4' of clearance to a window. I don't think you can do that with the concentric kit,can you???0 -
The GB is 1' clearance to a window0 -
this is pasted from the installation manual:
this is pasted from the installation manual:0 -
I think....
If you look deeper into the Direct Vent/concentric option, you'll find smaller clearences listed. I too think a foot is the listing. Chris0 -
OK-I'll look into the concentric clearances-maybe it will read differently. Thanks for the info.0 -
Funny
That's what it says it hte National Fuel Gas Code too...0
- 86.7K THE MAIN WALL
- 56 Biomass
- 105 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 69 Pipe Deterioration
- 951 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
