Cold start/Back Pressure
Dick Charland
Member Posts: 178
Usually no, depends on how long it has run etc. lack of temperature on boiler will affect draft in chimney etc. If the unit has run for a considerable period and has good draft on breech side and is still positive over fire, it could be a problem in heat exchanger or burner settings. All of this assumes natural draft boiler, good chimney draft and cleaning did not take place last spring with unit just being fired.
Cold
Question.
On a cold start boiler, is it common to have back pressure in the combustion chamber when it is fired after a cleaning?0
- 86.7K THE MAIN WALL
- 56 Biomass
- 105 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 69 Pipe Deterioration
- 951 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
