Primary/Secondary piping with two boilers
I LOOKED AT A JOB THAT HAD 1 SUPPLY LINE DOING 5 LOOPS OF BASEBOARD WITH TAKE OFFS IN DIFFERENT LOCATIONS.THE RETURNS ALL CAME BACK TO THE BOILER WITH A PUMP ON EACH.CAN I HOOK UP THE ONE SUPPLY TO A PRIMARY LOOP AND CONECT THE RETURNS WITH THE PUMPS PUMPING INTO THE PRIMARY LOOP.NOTE THERE ARE FLOW CHECKS AT EACH TAKE OFF.
  • Al letellier_10
    Al letellier_10 Member Posts: 3
    piping
    It depends on the set up, Anthony. A sketch would be great. Generally speaking, wtih a two boiler set up, you would join the returns to the supply and secondary the two boilers IN BETWEEN the supplies and returns, using a circulator for each boiler. I'm not sure what your layout is, so I can't answer your question accurately. Let me know if I can help further.
  • anthony_12
    anthony_12 Member Posts: 9
    primary/secondary piping
    i like to fax a scetch can you e-mail me your fax #. thanks info@parkplumbing.com
