Manual 3-way valve
Kevin__Flynn
Member Posts: 74
Viessmann, sizes 3/4", 1", 1-1/4", 1-1/2", 2".
Kevin Flynn
Kevin Flynn
Manual 3-way valve
Im having trouble finding a manually set 3-way mixing valve (diverter valve) any ideas? manufacturers?0 -
Sparco/Honeywell....
or Taco series 5000.....kpc
I was actually looking for something thats not thermostatic. do those companies make anything that isnt thermostaic.0 -
3 way valve
try paxton-corp.com.any 3 way valve with a handle should work.in the past i have used some from istec also.0 -
Use them all the time
Both Kitz and Conbraco Apollo have what your looking for.
Thread Only....If you find sweat tell me!
Apollo No. (I think) 70604-01, 3/4 inch, other sizes available.
Cost about 1/4 or less than the others options posted.
Boilerpro0 -
Thanks, I hadn't seen those..NM
manual 3 way
Danfoss has 1/2" thru 6", try www.danfossheating.com for info0 -
Taco 5000 series 3 way mixing valve
Taco 5ooo series is an excellent choice. Alternatively, you can use a Taco I-valve non thermostatic setpoint version. For your reference I have attached catalog data information for both products.
Taco, Inc.
Joe Mattiello
Technical Service Technician
joemat@taco-hvac.com
401-942-8000 X 484
www.taco-hvac.comJoe Mattiello
Taco Comfort Solutions0 -
3-way valve
try the tekmar 710 series manual non thermostatic0 -
I think I'll probably go with the tekmar...its the least expensive that i've found and it should work fine. thanks everyone0 -
WHAT SIZE?
Many great wholesalers actually stock 3-way manual valves.
How many you want?
wheels0
- 86.7K THE MAIN WALL
- 56 Biomass
- 105 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 69 Pipe Deterioration
- 948 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
