Can You Remove Sections From A Cast Iron H/W Rad
J. Waganer
J. Waganer Member Posts: 1
I have a cast iron radiator that i would like to make narrower, can i remove sections easily?
  • Mike T., Swampeast MO
    Mike T., Swampeast MO Member Posts: 6,928
    Are there small steel rods running across the radiator at top and bottom?
  • Jim Bennett
    Jim Bennett Member Posts: 607
    Read this...
    http://www.heatinghelp.com/newsletter.cfm?Id=20
    You'll have to cut and paste this.
    It is possible with the right radiator.
  • Bill Jirik,
    Bill Jirik, Member Posts: 54
    The radiators held together with threaded rod are the easiest but often it requires a little application of heat from a torch and the use of a hydraulic porta power or a couple of chisels, when putting back together I use silicone rubber (RTV) and let the stuff set up before applying any system pressure
