flat rate pricing
harvey
Member Posts: 153
Which flat rate manual do you use? I tried the search option with no luck as it is for only 90 day history. Any recommendations? Thanks for your help!!
harvey
Heeeeeeeeeeeeeere we go again! I'm a stayin outa D way.
Try this for starters.
http://forums.invision.net/Thread.cfm?CFApp=2&&Message_ID=85771&_#Message85771
Robert O'Connor/NJ.......Let the fun begin.0 -
Many great Flat Rate systems
We currently use Up front Pricing for our Pricing system software and printed Tech books. Look around there are a lot of great programs, check with sucessful contractors see what they are using and what the pro's and cons are. I also would check out Frank Blau's web site: http://www.flatratepricing.com/boc.html,he has extensive knowledge with Flat Rate programs and their success.Good Luck0 -
searching
If you use the pull down menu to select a time period for your search, the maximum is 90 days, but if you leave this field blank it will search much older posts.0 -
HEHEHEHE!!!
Good!
I was gettin' bored!
POPCORN!! COLD BEER!! GETCHER POPCORN!! COLD BEER HERE!!
Mark H
We're using Flat Rate Plus
www.flatratesystems.com/0 -
Oh Boy !
Maybe we can talk about FRP in relation to European boilers !?!?0 -
HEY
PROGRAM HERE,PROGRAM.
CAN'T TELL ONE FROM THE OTHER WITH OUT A PROGRAM.
Or
"Condensing Boilers".0 -
Flate Rating
a condesing European boiler with silver solder ??
Look Out ....
Back to WORK!
Youse guys gotz too much time on yer hanz. :-)0
- 86.7K THE MAIN WALL
- 56 Biomass
- 105 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 948 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
