Speaking of Professionals - Whats YOUR Expertise?
Ranger
Ranger Member Posts: 210
...picking out the proper size hammer for the job.I try to help contractors out of really deep holes that thay dug for themselves.I try to diagnose all types of machinery over the phone with very little,ommitted and or false information.I get to converse with some of the brightest minds...and some that are alittle dull.I guess my specialty
is just trying to be as helpful as possible.
  • hydronicsmike
    hydronicsmike Member Posts: 855
    mine is HVAC Control Strategies
    I have always wondered what each of the fine gentlemen who frequent here specialize in.
    Although I have gone through and successfully completed a Heating and Air Conditioning apprenticeship and worked in this field ever since, totaling now 14 years, I have specialized in HVAC Control Strategies.
    What is it that you have specialized in??
    Thanks for any replies in advance.
    Mike
  • Joe Grosso
    Joe Grosso Member Posts: 307
    Steam and Vapor Heating!
    but you knew that......
  • Mason
    Mason Member Posts: 102
    me too, I guess
    My wife says my specialty is hot air, does that make me a scorched air guy or could it be said that there is enough vapor to call me a steam guy..........................
  • S Davis
    S Davis Member Posts: 491
    Design
    Mike,
    Design and installation of boiler and radiant floor heating systems along with ventilation.
    S Davis
    Apex Radiant Heating
  • lchmb
    lchmb Member Posts: 2,997
    not really one
    I don't think I can say I specialize in anyone one thing. I do however truely love control system's and hydronic's. I like to start a new or replacement system from scratch and do it all....
  • Ragu
    Ragu Member Posts: 138
    Let's See...
    I used to specialize in installing great hot water systems and losing my shirt in the process. Really.
    My mantra now: "I specialize in the design and installation of high-quality forced hot water and radiant heating systems".
    If I like the customer, I will also accept them as an on-going service account.
    I don't do random-call cleanings, emergencies or service work without a good referral. I've lost WAY too much money doing that in the past.
  • Al Corelli
    Al Corelli Member Posts: 454
    I'm really good at getting sooty.
    Berlers and all types of wet heat.
  • Kevinj
    Kevinj Member Posts: 67
    specialist
    I specialize in client satisfaction if it's an old steam system, modern high pressure steam for industry, scorched air and chilled air...........I'm the guy who gets out of the boiler room and helps the techs and clients so everyone is happy !!!
    Kevin
    Unlimited Michigan Mechanical
    Michigan Class 5 boiler install
    Grand Rapids boiler operator/engineer
  • Dave Stroman
    Dave Stroman Member Posts: 765
    Cast iron heating.
    Dave in Denver
  • J.C.A._3
    J.C.A._3 Member Posts: 2,980
    Like ...
    LCHMB, I try to specialize in the job at hand. I look for all the little things that will make the job turn into 1 great thing. Controls are the biggest part but what the customer asks for is what I try to achieve.
    Knowing the ways that they can be achieved is my goal....I hope to mnake it a specialty as a rule. (not there yet but working on it) Chris
  • Floyd
    Floyd Member Posts: 429
    I have AADD......
    My wife calls our Co. Kolb's you name it we do it.....
    I just say that I'm a "jack of all trades, master of none"
    My motto has always been..."If it can be done, I can do it too"
    Always LOVE a new challenge....
    Floyd
  • Jeff Lawrence_24
    Jeff Lawrence_24 Member Posts: 593
    bringing it back up...
    Like Ted G said, my speciality is comfort.
    Forced air comfort. :) I try to do more hot water heat, but since we have to have the cooling down here combined with the high humidity, I'm sorta stuck.
    Jeff
  • Mike T., Swampeast MO
    Mike T., Swampeast MO Member Posts: 6,928
    Imagination of Order out of Chaos...
    ...and the ability to convert that imagination into reasonable reality.
  • Josh M.
    Josh M. Member Posts: 359
    Big boilers... Really big ones. Mostly combustion and controls.
  • Constantin
    Constantin Member Posts: 3,796
    Technology and Innovation Management
    I help people figure out what to do with their intellectual property portfolios. Like a gardener, the practice I run takes stock of the ideas, objectively rates them, prunes the dead ends, and then helps the client find a good home either inside or outside the company for the rest.
  • Radiant panel design. Often using your little blue box control strategies :D where's my binder, foo??
  • Scott Denny
    Scott Denny Member Posts: 124
    How I'd like to be remembered!
  • Glen
    Glen Member Posts: 854
    ditto for us here -
    including Vertomat and Rondomat set up and service. Residential hydronics - of all sorts - live long interest. Industrial gas setup and installs, etc.
  • hydronicsmike
    should be in the mail....
    ...foo too! ;)
  • Gene_3
    Gene_3 Member Posts: 289
    good question
    I guess I specialized in absorbing any good techniques and knowledge from all the great tech's I've had the honor and privilege to work with over the years, "most of the best and I'd say a high percentage of that learning came from my time at New England Mechanical Services", and now I specialize in transferring that knowledge to my students.
    NEMSI does something that maybe others should too, they have classes at the shop, taught by other techs, in boilers, controls, pneumatics, whatever, they cross train, it's like this " there will be a class on Tuesday, pizza, soda on {whatever}", you show up, you learn, they get better techs, it's a win win all around.
