plumbing question
Weezbo
Weezbo Member Posts: 6,231
  • Brian Maffioli
    Brian Maffioli Member Posts: 19
    Plumbing Question
    Question for some of my fellow plumbers.
    I just finished the plumbing in a brand new house and the home owner has complained of odor. I went to check it out and found that in one toilet the water level was very low inside the bowl. I gave it a flush, filled it back up and watched the level in the bowl gradually become lower. this toilet is vented of the stack but I dont think its a venting problem anyways. I allready ordered another toilet but I wanted to see what some of you guys thought.
  • Ed_26
    Ed_26 Member Posts: 284
    odor
    You will most likely find a crack or casting defect in the bowl. crane had this problem a while back. Had to change out several - they leaked on the floor in some cases. When the bowl level drops without other fixtures being used, usually indicates a leak -- as you suspect.
  • Dingo_2
    Dingo_2 Member Posts: 3
    CRACK
    or sandhole for sure .. allowing water out of the bowl and into the lower trapway where is is dumping into the soil piping ... no puddle is very possible
    Mike
  • ScottMP
    ScottMP Member Posts: 5,882
    Have had that happen
    also.
    COuld also be capilary attraction from something in the bowl like a rag sucking the water out.
    Either way, change the bowl.
    Scott
  • Cosmo_3
    Cosmo_3 Member Posts: 845
    I had this happen to me also, there was a hole between the bowl and the trapway. Gee wiz, when I told the guy al the supply house he said........ no I have NEVER heard of that one!
    Blah blah blah
    Cosmo Valavanis
  • JK_4
    JK_4 Member Posts: 35
    I haev seen both of these occur and would definitly check for one of these conditions.
