Looking for BIG irrigation box for snowmelt job
Mad Dog_2
Member Posts: 7,518
We have used two large ones side-by-side for real long manifolds. Mad Dog
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=210&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Big irrigation boxes are hard to find.
Looking for suggestions as to what you guys have used to burry remote manifold assys' outside (in a flowerbed.)
I need a minimum of 30" in length to squeeze in a large manifold. Depth seems to be a standard of 12" and width ideally would be 18" I'd rather not custom fabricate my own.
Any Mfg contact information would help.
Thanks.0 -
Ecoflex connection vaults
take a look at the attachement.
Large connection vaults (maybe not for a flower bed) and can be completely buried.0 -
Ecoflex vault not what I'm looking for
I'm looking for something similar to what the irrigation guys use. But, larger.Not by much though.0 -
Gary
Try looking at your local Electrical supply house, That is where I found are last one.
Mike Norgan0 -
Gary
Mike Norgan0 -
Try This
We used two of these 30" x 60" electrical boxes for a snowmelt job we recently completed. We got these from Graybar and they are manufactured by Strongwell. If I recall correctly, they were not cheap - about $1k/ea. including freight and they weigh about 350# apiece. -DF
valve box
Check out this company's website www.ndspro.com we use a lot of there drain products with very good success.0 -
Pre cast concrete manufactures
often times have a selection of concrete boxes used for leach fields and underground electricial pull boxes.
hot rod
We use Carson Irrigation boxes...
http://www.carsonind.com/pricelists/Irrigation_Price_List_Nov_05.pdf
They make one they call the mini coffin. It's a MONSTER...
What's nice is that you don't HAVE to did the whole body into the ground. You CAN cut the bottom half off and only dig half the way to China:-)
Usually around 150 smackers.
ME0 -
We use the same type of Graybar box on our snow melt jobs. The 30" wide x 18" box was just over $300 including the lid. And yes, they are heavy!0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 63 Pipe Deterioration
- 917 Plumbing
- 6.1K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
