cut in
James mo
Member Posts: 21
Remove and clean the pigtail that the pressure control mounts on. May be plugged.
CUT IN ADJUSTMENT
I HAVE TRIED MANY BASICS FOR MY STEAM BOILER,ITS ACTING UP.
I CHANGED THE THERMOSTAT, FLUSHED THE SYSTEMS RUSTED UP WATER. REPLACED THERMO-COUPLING CHECKED VENTS. BUT IT DOES NOT FIRE UP UNLESS I CRANK THE CUT IN WAY UP. ALL THE WAY AFTER ABOUT .5/#9 IS THEIR A SIMPLE EXPLANATION! I AM A VERY HANDY PERSON.0
- 86.8K THE MAIN WALL
- 56 Biomass
- 106 Chimneys & Flues
- 5.6K Gas Heating
- 104 Geothermal
- 69 Pipe Deterioration
- 952 Plumbing
- 6.3K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
