Smoke only from Oil burner
Tundra
Member Posts: 93
If you are getting smoke from a motor replace it. Also check the fuel pump to make sure it is not frozen and if youhave replaced the coupling recently check for proper length.
Smoke from burner motor
When oil fired boiler trys to start up it hums and smokes, period. What might I check for?0 -
Check the yellow pages for a service company.There was an error rendering this rich post.
- 86.8K THE MAIN WALL
- 56 Biomass
- 105 Chimneys & Flues
- 5.6K Gas Heating
- 104 Geothermal
- 69 Pipe Deterioration
- 952 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
