Air separator
Frank_39
Frank_39 Member Posts: 1
My residential boiler system I have in the house I just bought has the air separator on the supply side of the system. All diagrams I find show it on the return. Do I have to move this to the return side or is it okay to leave it on the supply? It seems to remove air okay.
  • bigugh_4
    bigugh_4 Member Posts: 405
    \"If it works do not fix it\"
    Kinda says it all!
  • A.J.
    A.J. Member Posts: 257
    Air separator
    Should go on the supply. Once you heat the water it was less of a ability to hold the dissolved gases intained in it.Leave it on the supply.
