Eccentric Couplings?
David Guest would be the most eccentric coupling I can recall.
Sorry Adam, I couldn't resist it.
It seems that the more eccentric you are, the coupling becomes much more acceptable, at least for a while :oP
On a note of more seriosity, do you mean "concentric" couplings?
I'm three "Coors originals to the wind" it's been a long day, so forgive my frivolity.
Bedtime for Bonzo.
The temp here in SW La. went from 84* to 60* in a matter of minutes, tornadoes ripped the hell out of what Rita didn't, and all the mosquitoe's within a five mile radius took refuge in MY house. Go ahead, laugh, I know you all are :O)
To be continued.
B in the frozen South. 84 this morning, 39 in a few hours.
  • adambuild
    adambuild Member Posts: 420
    Are they readily available? I need 2"x1 1/4". Some yoyo installed regular reducing couplings on 2 horizontal runs at the end of the steam mains and it sounds like the 4th of July!
  • mark  smith
    mark smith Member Posts: 112
    i guess it depends on weather your in ..Virginia ...., or ...say .. NYC
  • adambuild
    In Northern NJ.
  • mark  smith
    any branch of fergeson supply should have these
  • Mike T., Swampeast MO
    Mike T., Swampeast MO Member Posts: 6,928
    Brian:
    We got the same front here in Swampeast MO yesterday, but no tornados, just HUGE amounts of rain.
    He does mean "eccentric" for the couplings (but they're actually reducers). The smaller outlet is offset so that the bottom of both connected pipes stays level. Most commonly used in steam systems.
    p.s. I'd say that Demi Moore And Ashton Kutcher make a very eccentric coupling. Liza Minelli & David Guest actually makes some sense...
  • Brian (Tankless)
    Brian (Tankless) Member Posts: 340
    Gollllly! Am I wrong
    on both counts...no....yes?
    We only got 1.5" of rain, but those twisty things scare the cr44p out of me. That's 3 in my lifetime, 3 too many.
    You're right Mike, a Liza & David coupling is not eccentric, they're both nuts. But doesn't eccentric mean "off-centre", or is concentric "off-centre"?
    So, a reducing coupling where both of the bottoms of the inlet & outlet are at the same level, is an eccentric coupling, right? I understand it's usage in steam systems; it's to prevent condensate build-up in the lower "inverted hump" or "belly" of a regular reducer.
    So what's a concentric coupling?
    Now, back to this Demi Moore and Brian W. Swampster coupling. If you can arrange that, I'll come work for you for free.
    Thanks for the correction/education, Mike.
    Brian, in steam-challenged Swampland.
  • ScottMP
    ScottMP Member Posts: 5,882
    websters
    Concentric : having a common center
    Eccentric : off center; not having the same center.
    Eccentric couplings is the correct term for a coupling that has its coonections offset so as to have a common plane for complete drainage.
    Scott
  • Brian (Tankless)
    Sir Scott, thank you.
    It's now burned into my already burnt brain.
    Brain, I mean Brian, in Swampland.
