Weil McLain Steamer LEAKERS
Has anyone had problems with these boilers leaking between sections? We've seen 6 boilers in the past 2 weeks all with the same problem. They range in age from 3 to 15 years old. The local rep states that the warranty only covers the iron and not the gaskets.
  • Anthony Menafro
    Anthony Menafro Member Posts: 200
    Leakers
    I have seen only one one that seemed to be as a result of a dry fire. It was about seven years old. The gaskets were melted down, but other than that, they've been good. What size and model boilers are you referring to?
    Anthony
  • A.J.
    A.J. Member Posts: 257
    Weil McLain leakers
    Steve could someone is putting the wrong kind of cleaner in the boilers that is degrading the elastomer seals?
  • Glen
    Glen Member Posts: 854
    not from the seals -
    two boilers both WM - steamers - cracked from dry firing. makes a mess...
  • steve_6
    steve_6 Member Posts: 243
    no evidence of dry fire
    the models are EG & EGH and they don't have any additives at least according to most of the homeowners and we don't add any chemicals.
