Water capacity in C.I. Radiators
doug_10
Member Posts: 102
I am trying to figure out the number of gallons in a heating system to size the expansion tank. The system has C.I. radiators. How do figure how much each radiator holds? The majority of the system has 5 tube, 7 1/2" wide and in varying heights 17", 22" and 35". If I new how much water was in a section I could multipy that amount by the number of sections. Is this info available anywhere? Thanks!!
Old Rule of Thumb
IN PINTS! AND PER SQUARE FOOT OF EDR!
Column rad: 1.5 pints/sqft EDR
Flue rad: 1.75 pints/sqft EDR
Thin-fin tube: 0.807 pints/sqft EDR
- 86.7K THE MAIN WALL
- 56 Biomass
- 105 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 69 Pipe Deterioration
- 951 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
