puge station
hr
Member Posts: 6,106
you can flow backwards through the zone to purge at the supply header. Some zone valves and telestat type valves do not allow flow backwards. Also some circs now come with flow checks built in, and only allow flow in one direction.
Why not go with the flow and have the stop and purge cock at the return side?
hot rod
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=144&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
hot rod
Anybody have a diagram for a puge station on the supply header. Iusually install on return .Is supply better.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 105 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 69 Pipe Deterioration
- 951 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
