monoflo tee system
ralman
Member Posts: 231
on one pipe, then it travels to a normal tee, the 2 pipes after this tee follow the perimeter of the home and return to the boiler. The 2 return pipes come together in a y fitting. just before the y fitting are 2 valves that have welsbach stamped into the metal. I think they are for balancing the return flow. These valves are 1 14 inch NPT. They are not in good condition. Does anyone know what a good replacement valve would be?
ba. valve
nibco makes true balancing valves but globe or ball valves should work fine in this case. years ago we used plug valves for hot water systems but i have not seen them lately. a butterfly valve would also work but might be overkill for your application.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 105 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 69 Pipe Deterioration
- 951 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
