Indirect with mixing valve?
adambuild
Member Posts: 420
Is there an advantage to installing an indirect with a mixing valve for dhw? Cheaper to run? More efficient? When is it best to use?
for me
The advantages have been safety and more available hot water. The tank I have is set to about 140 and the tempered supply is at about 118. This gives me more hot available and less likelyhood of scalding. Also I find a more consistant temp at the faucet on a long draw. Dave Yates and others will tell you that it also keeps the nasty bugs at bay (legionella). So that's my two cents worth as a homeowner.
Larry (from OSHA)0 -
m
holy 90 degree.(lol)
Tempering Valve
Tempering valves will let you run the water heater hotter. This gives you more water at the faucet, but will also increase the standby loss of the dhw tank. It might be an easy way to increase an inadeqate tank's output.
Solar domestic hot water heaters typically are run hotter to take advantage of the panels as much as possible. Tempering valves should always be used when installing a sdhw system.
An anti-scald tempering valve is always a nice double-check that the water at the tap is never dangerously hot. Many applications require them for safety reasons. I like Caleffi's version.
-Andrew0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 947 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
