what gas press. does utilities give you in your area
8" - 9" here in the Bay Area.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=53&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
  • tim smith
    tim smith Member Posts: 2,850
    what gas press. does utilities give you in your area.
    Just looking to see what supply pressures you are getting in your areas. We only get 6" w.c. in our area which is low for some of the new condensing equip. Thanks in advance
  • 7\" in Denver
    and they get real pissy if you adjust it upwards...
    ME
  • J.C.A._3
    J.C.A._3 Member Posts: 2,980
    Here on the Gold Coast,
    (eastern Ma.) the regulator at the meter usually is set to 7". , though I have seen it as high as 9-10" W.C.
    Always check. You never know what the guys from the distribution companies have been doing. Look at the pages of the Boston Globe for the last few days, and you'll see what I mean! Chris
  • jim lockard
    jim lockard Member Posts: 1,059
    In Va
    Shenandoah valley 2psi /7 in WC your choice
  • tim smith
    Thanks all for reply's.
  • heatboy
    heatboy Member Posts: 1,468
    Residential is
    7" and commercial is as high as 5 PSI. I wish we could get 2 PSI for residential stuff.
  • Plumdog_2
    Plumdog_2 Member Posts: 870
    Up the pressure
    You should be able to design a small diameter gas distribution system within your structure; ask for a higher pressure reg., and then secondary reg it down to your desired pressure (but be sure to pipe relief vent to outside)
  • jim lockard
    2 psi
    Makes it nice you can pipe the house in 1/2 CSST ( wardflex)Best Wishes J.Lockard
  • jeff_51
    jeff_51 Member Posts: 545
    we get 2 psi here and is it ever great
    came from a place where is was 7" and had to be done in steel pipe only. Now we run everything into the boiler room in 1/2"copper and then regulate down. A centraley located manifold with shutoffs sure makes it easy to work on stuff
