OE Water Seal Balls Important
Steamhead (in transit)
Member Posts: 6,688
Whoever "O" and "E" are, I know they're cheering you on from the Other Side"!
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=367&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
OE water seal ball
Steamhead, just wanted to thank you for the time you spent scanning that article on OE water elbows and the balls inside. I did order some replacement balls, by the way 5/8" diameter. And now the traps work great!! In the future if anyone complains about a failing OE water elbow I am sure they are just missing a ball. Like you said, this design will last forever as long as you have all the parts. Thanks again for all your help.
Ted0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 946 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
