Ultra wall mount
hr
hr Member Posts: 6,106
those angle brackets that hold it to the crate! I mount one below the boiler to take some of the weight then lag bolt the top of the boiler to the studs or concrete wall.
On the jobs that I mount them on concrete walls, I grind the rivet heads off the bracket on the back of the boiler, then pull that bracket off. This allows it to fit tight against the concrete wall.
As a bonus you use the bracket you removed as a wall bracket for the next unit! Flip it over and it looks an awful lot like the ones you wait weeks for :) Been there also. They ought to include that simple bracket with every one.
hot rod
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=144&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
  • Tony_23
    Tony_23 Member Posts: 1,033
    Geez
    Gonna be a week for an Ultra bracket, and I've already waited 1.
    What does it consist of ? I can probably build one. Does it just hook under the rail that the shipping bracket is under ?
    It's **** to be "popular" sometimes :)
