oil burner interfering with television
Liberal Lenny
Member Posts: 33
The oil burner should have a seperate 20 namp service, if nor call a electrician, he also can install filters to help with the humming.God Bless.
Everytime the oil burner kicks on the television gets kind of fuzzy it is a beckett AFG burner any suggestions?0 -
Stop watching tv!!!!!!!!!!!!
Check out this thread-
http://forums.invision.net/Thread.cfm?CFApp=2&Thread_ID=30616&mc=21
its the electronic ignitor use a reg transformer and problem will stop0 -
TVI from oil burner
The most likely cause of tvi from your burner, is that the burner circuit is on the same leg of your electrical service as the receptacle your tv is plugged into, and the solid state ignitor is causing the problem.
Similar in nature as the humming that can occure in radio reception and amplifiers from flourescent lighting ballasts0 -
Try Radioshack
They may have a filter you can place between the wall plug and the TV.0
- 86.8K THE MAIN WALL
- 56 Biomass
- 105 Chimneys & Flues
- 5.6K Gas Heating
- 104 Geothermal
- 69 Pipe Deterioration
- 951 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
