1 1/2\" Boiler Supply Tap ?
Joe Brix
Member Posts: 626
it's because of the larger section models needed the flow. Why make a different casting section for a 2-3 section then a 6-9 section?
Or maybe because of the steam version of some of the hot water oil models use the same castings also.
The smaller steel btu boilers are all 1" or 1 1/4" for the most part.
1 1/2\" Boiler Tap.
What is the reason why the American boiler manufactors have been building small btu boilers with 1 1/2" supply taps ?0 -
So we don't
have to get different fittings.or halfta look at the spec sheets.... I wish.. but hope.I'm waiting for plug and play controls. Grundfoss is there.0 -
fittings
Now the most sort after iron fitting is a 1.5" x1.25"x3/4" tee..0
- 86.7K THE MAIN WALL
- 56 Biomass
- 105 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 69 Pipe Deterioration
- 951 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
