Buderus job B.N.
Bill Nye_2
Member Posts: 538
First time I ever stacked a Buderus. I've done about 5 Viessmanns. First time I used the grundfos 3 speeds with the check valve.
It is a 79 gallon tank, LT300, they did not want to run out of hot water. 400 gallon Roth tank.
The wooden stick under the return header is temporary[ see the lose hanger?] I ran out of threaded rod, 10' 6" ceilings.
This was a early '80's solar home, 6 thousand square feet with an 8 car garage. The beam over the boiler came from an old factory and was rotted and needed to be replaced. Hence the two lally columns in front of boiler. This held the job up two months. My partner Mark and I stayed until midnight last week to get it going.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=351&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
First time
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 939 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
