Water Quality
Dave Faust
Member Posts: 51
Will a water softener discharge "mess up" a thermoplastic sump pump?
I doubt it
since the last discharge is a rinse and that should leave the residue pretty well gone. Of Course the word plastic has a scary note to it. It might be that the brine rinse would or could wipe it out. Do you have the pump specs? if so check-em!0
- 86.7K THE MAIN WALL
- 56 Biomass
- 105 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 69 Pipe Deterioration
- 951 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
