Geothermal in Connecticut ... suggestions?
singh
Member Posts: 866
the igshpa website , and look up CT members/installers.
If vertical drilling required, the well contractor must also install the pipe,grout, test and antifreeze being compliant with his certification and EPA regs. $$$$
Mechanical contractor just connects HP and piping interior.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=377&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
I'm helping a friend plan a geothermal system for his new home in Connecticut. The system is going to be a closed-loop, vertical bore system that we'll connect to a water-to-water heat pump to serve an in-slab radiant heating system.
Does anyone have any referrals for qualified consultants serving the Connecticut area for the drilling, piping and grouting part?
Thanks0 -
Check the find a professional on this web site.
