1930's Crane cast Iron Radiators Ratings, HELP!
Eric Munn
Member Posts: 6
Does anyone have information on ratings for 1930's flat top water/steam Crane radiators? We bought the Book by Dan Holohan "E.D.R....", but it did not inventory the Crane radiators. We have a house restoration in New Mexico and are re-using the old Cranr radiators in a new hydronic system. We are battling it out with the Contractor and plumber and desparately need the rating information for these radiators. Anybody out there?
Eric Munn
Eric Munn
1
Do they look like normal free-standing sectional radiators?
If so, ratings were quite standardized and you should be able to find something similar in EDR
The "Burnham Slenderized" beginning on page 190 is good for most of the especially compact tube-type radiators. Dimensions (height and width of sections) might not be exactly the same as others, but a close size match will mostly likely have the same EDR. Again, manufacturers were remarkably good about using standardized ratings for similar products.
The US Capitol beginning on page 136 is good for "traditional" thin-fin tube rads. Section height and width (as well as EDR) are nearly identical among this type.
You can differentiate between these two general types by measuring the width of an individual section and comparing to dimensions in the book. The "slenderized" are significantly narrower.0 -
1930'sCrane Radiators
Thank you so much for your input... I will forward this to our engineer and Plumber...
I also found out that "Shafter Bros. Inc." in Montreal, Quebec, assembles new radiators with old parts from post 1935 radiators...they have rating information available there for "New Style Radiators" that works as well... looks like they may be using "Corona"? radiator parts? www.oldcastironradiators.com0 -
Can you
post a photo, Eric?Retired and loving it.0 -
Crane Radiators
Crane Radiator Photo
This is one of our beauties here...1930's Crane....
Thanks Dan...0 -
Great shape,
and the advice Mike offered will work just fine, Eric. Thanks for sharing with us.Retired and loving it.0 -
Am almost positive it's of the typical thin-fin tube variety--not the "slenderized".
If so, section width should be 2½".0 -
Definitely not \"Slenderized\"
which by the way was Burnham's name for their midget or "small-tube" radiators.
That Crane is a "large-tube" type. The section width (center-to-center) should be 2-1/2 inches. The ratings for the American Corto, National Aero, U.S. Capitol and similar units can be used for your Cranes.
- 87K THE MAIN WALL
- 57 Biomass
- 116 Chimneys & Flues
- 5.7K Gas Heating
- 109 Geothermal
- 70 Pipe Deterioration
- 987 Plumbing
- 6.3K Radiant Heating
- 389 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
- 48 Job Opportunities
