Boiler and Controls Placement
Joe_75
Member Posts: 57
Can an electric boiler and manifolds be installed in a crawl space. If so what are some problems that one could run into.
Not a problem at all. Give yourself enough space for servicing at you are golden. After that, its a typical boiler install. You don't have to worry about venting so thats a plus. Have an electrician check your load and supply power. Which boiler are you considering?0 -
Don, thanks for the reply. I think I am going with the lion-concept 23kw with outdoor reset.0 -
good choice, but...
lions are great electrics, but make sure you have adequate overhead clearance in your crawlspace (24" i believe) for element replacement.0 -
Thanks I will0 -
make sure
you have antifreeze protection.
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 938 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
