Triangle Tube Mini Smart?
Mars_3
Mars_3 Member Posts: 65
Has any one out there had any experiance with this product. Ive never heard of this product from triangle Tube Its called the Mini Smart and looks to be ok for small applications but I'd like some more input before I put one in. Any input would be greatly appreasiated. Thanks Mars.
  • Supply House Rick
    Supply House Rick Member Posts: 1,399
    Yes! Great Product!
    I have sold quite a few and we have had no problems to date. Will give you 3.5 gallons hot water continuous @ 180'F
    We have tremendous confidence in the Triangle Tube products. The Prestige has been perfect so far...
    Rick
    hot_rod Member Posts: 26,391
    I've installed a couple
    and they work just fine with the proper piping and boiler sizing. Quite cute also.
    hot rod
  • Metro Man
    Metro Man Member Posts: 220
    mini
    We use them quite a bid, space saver, cost, instantaneous dhw. The only draw back is if there is a pressure regulated anti scald device like a shower head you may get some complaints for insufficient hot water. We always use a flow restrictor.
    Extra insulation around the outside helps. You can also manipulate settings on prestige for various outputs.
