Leaking CI Rad
dann crist_2
Member Posts: 37
Any suggestions? HO bought a 60" antique CI rad from a "home resource center" (AKA a second hand store for old stuff that someone already took out because newer is better) and wanted me to install, (old home, new addition, old steam system converted to hot water many years ago). After refilling and refiring the system the radiator shows leaks between the sections in two or three places (small leaks but leaks nontheless) Does anyone have a fix for this problem??? There is an enormos amount of water in this system w/ 3" pipes throughout the house. Burnham 130,000 cast iron boiler. New zone has three CI Rad, two from basement of original house and this "new" monster. Thanks for any suggestions in advance.
- 119 Chimneys & Flues
- 114 Geothermal
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
