Expansion tanks
Empire_2
Member Posts: 2,340
To answer your question The air cushion in the tank can be absorbed by the system through gravity circulation. On a down cycle, the cooler water laddent with air tends to move to the system while water from the system moves to the tank. Using the Airtrol tank fitting will eliminate this problem.
Mike T.
Mike T.
Exspansion tanks
Anyone have any good suggestions or reasons that exspansion tanks are always filling up over time?0 -
And also, if you are using automatic air vents anywhere in the system, the tank will get waterlogged alot quicker than usual.0 -
especially when the
Especially when the pump(s) are on the return side of boiler0 -
What kind of expansion tank? Is this a diaphragm-ed tank?
If not, be sure to use a scoop rather than a micro-bubble eliminator. Micro-bubble elims (such as a spirovent) can over time steal all of the air from a conventional unit.0 -
Does it have a bladder?
If not, be sure to use a scoop rather than a micro-bubble eliminator. Micro-bubble elims (such as a spirovent) over time can steal all of the air from a conventional unit.0 -
exspansion tanks
This tank is on a large commercial job, I do NOT believe it has a bladder, I believe the pumps are located on the return side of the system.0 -
air and water mix
Especially under pressure and heated. What are the size of these tanks. Could you use an airtrol fitting?
http://www.bellgossett.com/productPages/Parts-Airtrol-Tank-Fittings.aspan ATF fitting ?0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 63 Pipe Deterioration
- 916 Plumbing
- 6K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
