Solar Storage Tank
singh
Member Posts: 866
Seems like a Phase III would be a good application for solar. Providing you don't need a second coil.
Does any one have thoughts about this?
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=377&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
SDHW
Is this SDHW preheat? The Phase III should work great, as will any indirect with a good heat exchanger.
I wonder if the tank-in-tank design might result in a higher return temperature to the collectors than a coil-in-tank design? Then again, it might not. I must admit, I have not watched a tank-in-tank water heater in action with a thermometer in my hand and compared it to a coil-in-tank design.0 -
This would be a pre-heat for a tankless.
Of course I'll have to put a mixing valve between the two so
tankless would work.
I was thinking a tank in tank would also give you better xchange? And on low producing days, the tankless would still have a lower temperature rise.
thoughts
My first reaction is that a coil-in-tank would have a lower return temp to the collectors. Also the collector loop volume would be less with a coil, which I think is better for a solar heating system.
In my opinion, it is very difficult to beat the price and quality of Crown Megastor tanks. The MS-119 is a nice design with more coil surface area than a Vitocell 300, and the MS-80 and 119 are also available in a dual coil.0 -
Check out the Viessmann tanks
in the new "Green" section here. Under Solar Technology file. Thanks to Terry and Viessmann for providing all that solar lit. There is a gold mine of info in those docs!
Notice how a stratification tank is built their 353 model.
Also that rather unique 050 tank that has a smaller DHW indirect tank inside the large tank to eliminate potential DHW stagnation in the large vessel. Very clever!
I'd like to see a Phase 3 tank with additional taps mid way up. Then you could use that stacking principal and possibly dual heat inputs. Upper for boiler lower for solar.
I may have to strip a phase 3 down and do some drilling and weldingThe large amount of surface area in a tank in tank style should be a plus. Seems like a less expensive method as opposed to hundreds of feet of coil?
hot rodBob "hot rod" Rohr
Living the hydronic dream0 -
i saved some pics from a link in one of the readings...
i was sorta thinking...'hey! Hot Rod would dig this!
it is linked through aee-intec translate page google it wont copy and paste from my favorites list..lets see if i can find the pic which leads to the pic you would definitely dig :)way sharp projects ...plenty of reading material and pictures to clarify them...cha ekit Out
it is bolted up to an Array of storage tanks...Nice0 -
solid question...and one that I am mulling over
as I start my solar driveway. Mad Dog
- 86.7K THE MAIN WALL
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 939 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
