radiant over slab
Joey B
Joey B Member Posts: 16
I read in this months PM about installing radiant over an existing slab. Is insulation ie double bubble, nessesary over existing slab in a basement before laying tubing and new concrete?
  • kevin coppinger_4
    kevin coppinger_4 Member Posts: 2,124
    don't waste...
    your money w/ bubble foil insulation/crap...it is not the way to go, it has no r-value!....use styrofoam...
    hot_rod Member Posts: 26,645
    Is there
    insulation under the current slab? It sure would be nice to get a thermal break somewhere in the build up. I'd feel more comfortable with 1/2 or 3/4" EPS boards to bubble. It is designed for this purpose has true r-value and weight bearing ratings,
    I'd also put an insulation band around the edge for a thermal break and expansion.
    hot rod
  • Paul_11
    Paul_11 Member Posts: 210
    I agree with you Hot Rod, 1/2" or 3/4" EPS is better than bubble wrap when you can handle the height.
    Would you also use EPS under radiant floor pours, slab on grade, rather than Styrofoam if height was no issue.
    Respectfully,
    Paul B. Shay
    pshay@arealgoodplumber.com
    LMP 1307
    LMFS 654B
    OUR MISSION: TO PROVIDE WORLD CLASS PLUMBING, HEATING, AND SPRINKLER SERVICE TO EACH AND EVERY CLIENT WE SERVE, FAR EXCEEDING THEIR HIGHEST EXPECTATIONS!
    Since 1990, I have made steam systems quiet, comfortable, and efficient. We provide comfort while saving the planet.
    NYC RETROFIT ACCELERATOR QUALIFIED SERVICE PROVIDER
    A REAL GOOD PLUMBER, INC
    NYC LMP: 1307
    O:212-505-1837
    M:917-939-0593
  • Glenn Sossin_2
    Glenn Sossin_2 Member Posts: 592
    AGREE
    100% Use some type of foam insulation to minimize downward heat energy losses - actually very important to insulate the edges also - depending on the depth of slab to grade, the edges can lose as much as the underside of the slab.
    Our customers have been very happy using a product called the barrier. Think of the foam coffee cup you get at McDonalds, Burger King, - it's very thin, yet hardly any heat energy comes through to your fingers.
    Check out the attacments. This should help you.
