PAP Fittings Universal?
I know kitec fittings fit, with elbow grease, into a mr. pex PAP pipe.
I have to think that given the extra tightness, the reverse is not true. But I have not tried that, since I have no kitec pipe.
PAP Users Please Respond
I would like to know if anyone is using PAP fittings and mixing manufactures.
I am told that not all PAP fittings will work with all manufactures of PAP. is this BS or is it a fact.
Originally we were told this by PEX manufactures that a system is a system Well low and behold now we all use the same cinch clamps with all brands, mix manifolds, play with other fittings etc.
So, is PAP universal or are the tolerances that far off that Manufacture A's fittings will leak if used on Manufacture B's tube.
Experiences??
Thanks,
wheels
