Kohler Type 22FC-7 Cast Iron Coal Burner
Water-Lou Mancusi
Member Posts: 11
I've just been asked to quote a job to replace the above mentioned boiler. I ask if someone could explain the boiler plate information to me so I could calculate the size boiler I should quote. This is a retrofitted oil fired, hydronic, monoflo convector loop system with a 9" chimney flue. There are cast iron convectors, which I've never seen this style before, and four column cast iron radiators and baseboard.
The plate reads as follows:
Kohler Type 22FC-7
Valve Capacity 178lb/hr
Gal Oil 1.75
Steam 490
Oil Fired Baffled
175* Water 785
Are these numbers sq. ft. of steam? What is 785 of hot water? The house is 1300 sq. ft.
HELP!
Kohler Type 22FC-7
Gal Oil 1.75
Steam 490
Oil Fired Baffled
175* Water 785
HELP!
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
