Rehau/PEX fittings needed
Don \"Grumpy\" Walsh
Member Posts: 184
That single circuit add-on is mighty expensive. I would be looking to exchange the 10 circ for a 6 and a 5 if I were you. The 3/8" R-20's are the way to go. If you can't find them in your area, e-mail me, I have a bunch in the shop.
Need source for Rehau/PEX fittings
I recently purchases a 10 circuit Rehau manifold with flow gauges, etc. It turns out that I need an 11th circuit. I know an extension kit exists but I haven't found a source for it.
This is for an industrial application cooling vacuum tubes in a unique multi-tube amplifier. I would like to use quick connect fittings with 3/8" tube. I have found a source for the adapters to the manifold, although it's a different brand.
I haven't been able to find 3/8 tube to 3/8 FPT for the application end. I could in a pinch use 3/8 tube to 1/2 FPT but that involves a pipe thread adapter.
Any suggestions about where I can find these fittings. Everywhere I've looked on line seems to have a limited choice of the more popular stuff.
Jim0 -
Rehau 250225 is for the extension kit.
Rehau 267507 3/8xR20 for the fittings.
Hope this helps.0 -
Thanks, Mike. That's a big help. - Jim0
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
