PIN secured T'stat
Jed_2
Member Posts: 781
Thanks! I knew they were out there. Invensys-Robertshaw offers the 9700i, and White-Rodgers has the IF97-1271. Both will fit the bill.
Thanks a bunch.
Jed
Thanks a bunch.
Jed
For Apartment Control
Is there a "simple" digital thermostat available which can lock out set point with an installer/building owner PIN security access feature. I know the Vision Pro's have "installer access" codes to do this, but not changeable. Someone told me there is such a thermostat that allows a PIN to be entered to lock out temp adjustment.
Has anyone heard of this?
TIA,
Jed0 -
Bump
I know there are a few, But...
"Invensys" , Which I have in my house is really nice. I can lock out my wife of all people...:-) Also has fan timed intervals if needed to circulate air when desired. All programmable. Has optional outside air temp acc. and is remote sensor capable. I like it.
Mike T.0 -
W/R
Did you check White-Rogers?0 -
yep invensys
Easiest ones to program I have ever seen don't even really need to look at the instructions they are so well done.0
- 87K THE MAIN WALL
- 57 Biomass
- 115 Chimneys & Flues
- 5.7K Gas Heating
- 107 Geothermal
- 70 Pipe Deterioration
- 983 Plumbing
- 6.3K Radiant Heating
- 389 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
- 48 Job Opportunities
