PEX for commercial hot water
kevin coppinger_4
Member Posts: 2,124
the limits of the PEX..but it probably should be ok. Honestly pex-al-pex would be a better choice...IF local codes allow it. kpc
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=323&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
I was thinking of maybe using PEX piping to pipe HW down an existing metal stud wall for new fintube mostly to maybe save some effort getting the pipe in the existing wall with out tearing out too much drywall.
There are two questions:
The rating of the PEX tubing for use with a 200 deg F hot water system.
8' or so of the tubing being supported from above in the wall.
Any thoughts?0 -
I'd use
PAP or Viega FostaPex. Buy the straight lengths and slip insulation over it as you put it in.
It also needs to be suspended or fastened to the stud as per code and manufactures installation info.
Bare, barrier pex will move in the wall and could be a noise issue, especially if you use coiled pex.
hot rod
- 119 Chimneys & Flues
- 114 Geothermal
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
