Vitodens troubleshoot = no DHW
[Deleted User]
Sometimes, if the brain "sees" a brwon out ocndition, it forgets its function in life.
Reboot the onboard computer and things should return to normal.
May want to consider an UPS if it continues to happen.
ME
ME
All was well for 1 year and now no DHW. Seems the boiler just runs at 84 degrees and never bumps up to heat the DHW.
No faults that I can see. Any ideas? Thanks0 -
We had that once
coincidental to a power outage on Thanksgiving night. A re-boot solved it.
I offered that nugget up in similar thread not long after that time. In the end for that questioner it was a loose spade connection on the DHW cylinder.
BTW, the Vito has run flawlessly since then."If you do not know the answer, say, "I do not know the answer", and you will be correct!"
-Ernie White, my Dad0 -
NO DHW
Check coding. Call Viessmann0
- 87.5K THE MAIN WALL
- 123 Chimneys & Flues
- 118 Geothermal
- 15.9K Strictly Steam
- 57 Water Quality
