Too easy
Brad White_9
Member Posts: 2,440
Looked at a replacement job yesterday. HO wants to upgrade from 1954 and save some gas.
Shouldn't be too hard. Pennco wet base 144k input w a B&G 1/6 hp HV circ driving thru an 1-1/4" monoflo loop feeding steel bbd (the kind that looks like CI at a glance).
They added on 1/3 of the house 5 years ago.
The original house has that whisper thin FG, about 2", in the walls and 6" in the attic. Wood SP windows w/ swing open storms.
Heat loss is done. I gave it a little "cushion", even though I know it's not necessary. 59k and change.....
You don't get THAT at HD ! Let 'em sell all the PEX they want :)
Sounds a lot like my house..
I installed a Vitodens, LLH, RS Sensor, and Vitocell water heater. Cut my gas bill by about 45%. The RS Sensor acts enough like a normal thermostate that most people would not know that it does a bit more than that.
Perry0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 75 Pipe Deterioration
- 15.6K Strictly Steam
- 49 Job Opportunities
