Granite pavers for snow melt
Mars_3
Member Posts: 65
Hey guys, Ive got a snow melt system that the contractor want to use tumbled granite pavers on. The pavers are approx, 6" W. X 9" L. X 3" deep. The sub base for the system is compresed road base, on that I have a thermal break, followed by my 6X6 wire mesh with tube attached, onto that is 3" of low sillica sand. all the paver systems Ive ever done have been the man made interlocking type. My concern is that the pavers will move around due to the un even edges that are inherent in this system. Has any one done a system of this kind before? If so is there anything I need to be aware of. Thank for any and all input. Matt R.
I have done............
a side walk apron on a house with cobblestones, that are about the same size as what your saying in the granite stones. I had a clay base, with a foil double bubble poly insulation barrier, 2 " of stone dust, and the cobble stones placed on the 2" of stone dust with stone dust filling in the joints between the cobblestones, it has been in for 2 years now and I have had no complaints or call backs on it. I would tghink you could drive a car on it as well if you wanted to.......I think your situation would work if the stones are tight with out a ton of movement.
Steve
We Did a driveway snow melt job using pavers. Base layer if i remmeber right was a crushed stone / stone dust base 1 foot deep for good drainage. Then we used insultarp for the insulation layer. Put the wire mesh ontop of the insultarp. Installed the tubing and coverd with a layer of 2 - 3" of stone dust. The pavers were installed and came out awesome. I thought the same thing that the pavers would move around considering the base but the do not.0 -
Need Suggestion For My New Construction
I am planning to construct my dream house and I have several plans for its construction. I am planning to use various modelled granites, which are durable and beautiful with unrivalled qualities. As a part of my search for best paver's I came across Granite cobblestone, Porphyry paver's and many others. I want to use them in my house. Are they worthy? Anyone used these before, Any suggestions will be highly helpful.0
