pneumatic versus electromechanical controls
Brad White
Member Posts: 2,399
a regular supplier such as Johnson Controls, Automated Logic, Invensys, Siemens, etc? Each can give you a sampling of their controllers and requirements.
Most VAV box controllers are fairly standard affairs these days, with integrated motors and control boards. DDC or straight electric/electronic versions are available.
You may (may) be able to salvage the flow-cross volume pick-ups but the k-factors have to be known for programming purposes.
Most of the sequences are "canned" (pre-programmed into the board) being so common.
The controllers I see are field-installed on factory-naked boxes whereas in years past the controllers were shipped to the VAV box factory for installation there. This should tell you that field adaptation is commonly done.
The controllers I see also have integrated damper motors and so slide over the shaft. Knowing the shaft diameter, round or flat and other characteristics is helpful.
-Ernie White, my Dad
converting pneumatic controls
i have a custoomer that we have been servicing their hvac system including aa honeywell pneuamatic control system. due to many inoperative vav boxes they requested i put together a quote for converting from pneumatic to electromechanical control system and upgrading the vav boxes. where do you suggest i start collecting my information from. and any other input would be appreciated.
jh0
