From our friends at Taco (Dan H.)
DanHolohan
Member, Moderator, Administrator Posts: 16,732
TACO ISSUES EXPANDED BROCHURE ON ITS 4900 SERIES
AIR/DIRT SEPARATORS
Fall River, MA, April 3, 2007 Taco, Inc. has issued an expanded brochure on its full product line of 4900 Series Separators for micro-bubble air and dirt removal.
4900 Series Separators come in standard and high velocity models, in both air and air/dirt versions, and can be equipped with either removable or non-removable covers. All 4900 Series Separators come with integral PALL ring technology stainless steel rings enclosed within a basket inside the separator vessel that separate air micro bubbles, sand, dirt and rust within a hydronic heating or cooling system.
Micro-bubbles are removed through a process of coalescence; sand, dirt and rust particles are caught and sifted to the bottom of the tank, where they can be removed through a blowdown valve.
Pall ring technology, imported from Europe, has been extensively used in the processing industry for many decades and has been employed here in the Taco 4900 Series as a patented, first of its kind use.
The new 4900 Series brochure includes a full description of Pall ring technology and process within its features and benefits section; a full applications section on air control and air control systems, and a full description of types of air separators offered by Taco.
There are also sections on 4900 Series selection examples and typical specifications; pressure drop charts for all 4900 Series models, and specification tables.
A copy of the 4900 Series Air Separators Standard and High Velocity brochure can be obtained by calling Taco at 401.942.8000 or can be downloaded at www.taco-hvac.com by clicking on Products - Air Elimination & Control - Air Separators 4900 Series.
4900 Series Micro-BubbleAir/Dirt Separators are manufactured at Tacos fabrication facility in Fall River, MA, and are designed and constructed to ASME standards.
Taco, Inc., headquartered in Cranston, RI, is a leading developer and manufacturer of pumps, tanks, valves, electronic controls and accessories for use in hydronic heating and cooling applications.
AIR/DIRT SEPARATORS
Retired and loving it.
- 87.8K THE MAIN WALL
- 130 Chimneys & Flues
