hot water radiators hook up with plex tubing
doug o'connor
Member Posts: 17
i have 1/2 inch plex tubing.
Can I use it to loop hot water radiators with source?
i have a polaris 100,000 btu with manifold for zones.
Tube
PEx is PolyEthylene, crosslinked.
Be sure to run the radiators in parallel rather than in series, as one might do with baseboard. Does the sube have an oxygen barrier? The size required depends on the heat load served by each radiator.0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
