Question on TSP cleaning
Adam Buchsbaum
Member Posts: 10
I have a few questions about cleaning with TSP.
- Various instructions I've read on this site suggest pounds per BTU input or pounds per gallon of boiler water. Which method is preferable to follow?
- If per gallon, how do I know how many gallons are in the boiler? I cannot find it in the specs anywhere; should it be on the boilerplate? (I have a Weil-McLain EG-65.)
- Should the boiler be filled to the top or to the normal half-way mark for cleaning? If the half-way mark, how does the whole thing get cleaned?
- The instructions on the box of TSP state that it can etch glass. I don't think I've seen any suggestions here, in Dan's books, or on the Weil-McLain web site to replace the sight glass after cleaning or perhaps shut off the valves to the sight glass during cleaning. Is this something to worry about?
Many thanks!
Many thanks!
another question...
Where do you dump it when you finish?
Noel0
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
