W/M Ultra help
mikea23
Member Posts: 224
New York on LI
W/M ULTRA HELP
I installed a WM ultra natural gas 230 about 4 months ago in a new home got called no hot water. I got there and there is no display boiler will go into pre purge when turned on then off but wont fire at all I checked all fuses in the circut board all looked good and checked out good last resort I replaced them anyway.still no display. My experiance tells me the board failed and needs replacement. If that is the case is it a stocking part. The customer is ok for tonight but after a cold shower in the AM things will change fast
Mike0 -
Board
without speaking to W/M I would suspect the board. My supplier has an after hours service and they keep all parts in stock, boards included. Good luck.0 -
Where are you located?
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 64 Pipe Deterioration
- 917 Plumbing
- 6.1K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
