Hotter water leaving an injection system than entering
Ron Schroeder
Member Posts: 995
you right the concrete curing process is heating the water as it goes through?
How many possible causes can you think might be the....
reason for said phenomena? *~/:)
ok, this is a test. you only get one answer.....
after we all make a contribution ,lets see if there might not be just one more:)
let me start it off with....because the new slab was pumped up with "high early" and the cool water being pumped in, is being heated by the cement....:)0 -
- 129 Chimneys & Flues
- 122 Geothermal
