Ray Burner
oil-2-4-6-gas
Member Posts: 641
Ray Burner
i do commercial heating on some dinosours i have an aeop-144 size 125 i'm trying to locate a gear that turns the oil pump --the markings are celeron 1084 A --would anyone happen to have one ?0 -
I came upon this exact problem with a Ray burner before. We ended up having to replace the burner. So what we did was the next time we replaced a Ray burner we saved it! That was my last employer but I am sure that I can get a part off it for you. If you can get me the dimensions of your part I will see if I can help.0 -
thanks for the offer josh --but if idealy i'm looking for new old stock --if not i might have a few made --just not sure of the material if i have to go that route0 -
bump.
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 938 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
