Local Plumbing Supply Doesn't Carry Thermostatic Vents
Garret
Member Posts: 111
There are a half dozen danfoss thermostatic radiator vents at my local preservation warehouse (PACA). To bad they're vents, or I'd have snapped em up (I have two-pipe, so I need TR valves).
http://www.pacacc.org/
I'm not sure if they do direct sales by phone or email. You could contact em to ask. PACA's prices are very reasonable... I bet you'd get em for a few bucks each.
The warehouse is only open Wednesday nights and Saturday mornings, though. I'll try to remember to head over there on Wednesday to see what the model number is. And if they can't mail order them to you, I could pick em up and ship em myself.
Pro folks, is it a bad idea to reuse these? They look to be in good shape, and were likely removed when a building was "upgraded" or demolished.
-Garret
-Garret
Local Supply Doesn't Carry Thermostatic Valves
I have a one-pipe steam system with an 9-yr old gas-fired boiler set at .5 psi cut-in. I just finished insulating all the the naked pipes. (Previous Owner had the asbestos wrap removed.)
Two second-floor rooms are now overheating; and I've determined from all your great information that I need to install thermostatic vents on them. It looks like the Danfoss RA2000 1PS Thermostatic Radiator Valve are exactly what I need.
I'm trying to buy local--but so far three of the closest plumbing supply houses don't carry them and claim not to be able to order them. Any suggestions?
I live in Northern NJ. Thanks, Pat0 -
Can your Wholesaler
Special order this for you? Have you tried the internet? We special order every day and usually ship direct to customer. Just a suggestion...
Rick0 -
email
me your location and I'll see if I can point you in the right direction. dennis_wood@danfoss.com
DWood0 -
in north jersey
Pat i am located in north jersy and can usually get them in a couple of days have you tried universal supply group they can get them but there really only wholesale ,also try ridgewood corp they mite be able to get them .Here's my e mail if you have any promblems RDEUZA@aol.com peace and good luck clammyR.A. Calmbacher L.L.C. HVAC
NJ Master HVAC Lic.
Mahwah, NJ
trv's
check out www.webbsupply.com, go to specials they are right on the first page. or call them at 800-994-9322 and ask for danfoss #013g8250 and danfoss #013g0140 should be around $60 both together plus actual shipping. remote sensors are also available.
use any straight air valve. if you have gorton's on the other radiators neither the Hoffman 41 nor the Hoffman 1a will work. because of their venting capacity.
HitzKup0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 939 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
