Radiator reflectors
Eddie M
Member Posts: 26
i read that i can make my own with cardboard and aluminum foil with the shiny side facing the radiator. Will that work? see attachment
http://www.smartliving.ca/tenants/radiator.htm
Has anyone heard of or used radiator reflectors? They go on back of the radiators to keep heat from excaping through the walls. they look like a metal sheet. Where can i get them?0 -
Try foil bubble if visual is not the issue; just staple to the wall. Awsome.0 -
Kitchen Cabnet or Home Depot
I have seen people line the back of convector cabnets with tin foil.Reflective side out. Behind free standing cast irons I seen that styrofoam reflective panal used to rap houses for siding.. Sheet of stainless would be nice, keep it off the wall a little to prevent contact heat transfer..0 -
Should work as well as any. You might find that sheet mylar (available at craft stores) is easier to work with than aluminum foil.0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 64 Pipe Deterioration
- 917 Plumbing
- 6.1K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
